All 4 incomings calls to the related Extenssion
Satpal Singh
I have GOIP4 Voip GSM Network Gateway.
I want to route every GSM Sim call to a different extension.
Like Sim 1 received by Extn 1001 and outgoing calls by ext 1001 should be using Sim 1 only.
So that we all can make and receive calls to our own business, if needed we can transfer the calls via extension. Is it possible?
Depending on how the gateway works, yes it could be possible. You would need multiple trunks in 3CX to connect to it and then your inbound/outbound rules would do the rest.
This is not a supported device however, so you'll have to configure it manually and figure out the right parameters to use.
Thanks, So only I have to add 4 SIP Trunk for all my 4 GSM network, and configured all accordingly., Right?
But I added 1 SIP Trunk to try it, and added ID and Password in GOIP4 Device Line 2 (SIM2), but it is not working.
Can you check it over anydesk? wa.me/+971542525263
Like I said, you'll need to figure out how to configure both the gateway (headers, protocols and such) as well as the 3CX side of it.
But yes, basically you need 1 trunk per SIM card. If the gateway can even do that.
Thanks, Will try it now.
I added one gateway and configured it with SIM Line as follows
Basic Voip: Config by Line
Incoming are fine. All defined SIM Line is configured with respective Extenssion.
But Outgoing is fixed with Sim2 (Line2).
Where is the mistake?
If the gateway is capable of sending a DID number (any DID number), then you can create rules based on those numbers, and route the calls to the desired extension, all over one trunk group.
If you have already decided to go with 4 different trunks, then each will require a different local port number. The gateway options will have to be set to determine which SIM outbound calls over each of the trunks use. It may still be set to overflow from one to another.
admintest
