Solved Android and iOS app is showing connecting ..
Escom Tech
Hi Team,
In android and iOS app shows connecting , we can't make calls.
Please advise, Thanks
Hi @Escom Tech
Thanks for your feedback.
Can you please check whether you can connect to the webclient from within the mobile device browser? Just as a quick test?
Also this usually mean that 3CX Tunnel is disabled for the extension. Are all the extensions experiencing this? Can you ask the administrator to check in Management Console to confirm this setting is Enabled?
Management Console > Users > Extension > Phone Provisioning > Select 3CX App in the Dropdown menu > Use 3CX Tunnel for remote connections (3CX App only)
Web client and desktop app is working fine. These settings are also same as well. But in mobile , tablet or ipad same issue for all users.
Now it's working, Port 5090 was closed before.
Thank you for
SDNM
