android and ios register timeout
weekaa
hi all
problem when try register 3cx android and ios soft phone clint
have 2 Untitled.png Untitled1.png pic for port and 3cx clint try more times to register always ( register failed, timeout )
any one help
Is this over 3/4G connection? Or WiFi?
Is the connection stable?
Does the logging on 3CX give any indication as to what the issue might be?
Are you running the latest supported soft clents for the version of 3CX that you have?
Dear Eddv123
about your Questions
Is this over 3/4G connection? Or WiFi? 3/4G and wifi same ( work in internal network )
Is the connection stable? YES
Does the logging on 3CX give any indication as to what the issue might be? message is ( Provisiong error )
Are you running the latest supported soft clents for the version of 3CX that you have? Yes last soft
Mahlon
