- Joined
- May 30, 2016
- Messages
- 81
- Reaction score
- 10
Hi all,
I'm troubleshooting two related problems for a customer using the 3CX Android app, and I'd like to know if anyone has seen them and found a fix.
Environment
- 3CX V20 Update 10 (Build 1785), self-hosted
- Android app 20.8.0
- Affected devices: Blackview BV5300 Pro and two Xiaomi phones
- Firewall in front of the PBX is a dedicated cloud firewall, no IPs in the 3CX blocklist
Problem 1: "Not registered"
The app goes to "Not registered" and then stays on "Connecting..." after the phone passes through an area without signal, and sometimes after a call. It never recovers by itself. Only a app kill and restart fixes it, until it happens again. Already done: app updated, Keep Active enabled, battery optimization disabled for 3CX.
Problem 2: one-way audio after network switch
During a call, if the phone switches from WiFi to 4G/5G (or the other way), one side stops hearing the other. The only fix is to hang up and call again.
What I tested
I registered an iPhone 17 (iOS app 20.0.24) and a Galaxy S26 on Android 17 (app 20.8.0) on the same PBX and simulated a WiFi drop during a call, continuing on 4G/5G. Both external calls and calls to an internal extension (web client) were fine: about 2 seconds of interruption, then audio resumed in both directions. I could not test smartphone-to-physical IP phone.
So the PBX sometimes seems to handle the network change correctly with recent devices.
Questions
- Has anyone seen this on Blackview or Xiaomi phones? Did you find a fix?
- Any known issue with the app not rebuilding the connection after a network change on older Android versions?
- Is there a way to collect useful logs from the app for this?
Thanks!
Environment
What I tested
Questions
Thanks!
