Android client 16.0.0.35 on Sony ZX1 47.2.A.6.30 (Pie February 2019):
nobody
My findings:
Does indeed logon faster to the server when opening the app. I did not experience a lag or error like previously - improvement.
Call quality seems improved if mobil coverage is good - improvement (still if reception is not optimal problems using the 3cx App for calling or answering a call).
Power drain problem seems resolved compared to a previous beta, now similar to older release version - improvement.
I can use my PLT3200 with BT and I am able to answer a call using the headsets speech commands - improvement.
But the problem if I try to dial a contact from my android contact list (using Blackberry Hub) is still as before: I tap the contact, then tap the number, I am asked if I want to use 3cx or built in dialer, I tap use 3cx once. 3cx opens but number is not dialed. However if I go into the contacts listing of the 3CX app touch the android contact, then tap dial it works as expected. Dont know if this relates to blackberry hub, because If i go into the native android contacts I am not asked which app I want to use for making a call, it automatically dials using the android mobile phone dialer, so I cannot try what would happen.
PS: how about bluetooth headset support for the Windows Softphone App?
Reactions: nb
Thank you for your feedback @nobody ,
From your description it seems your issue is relevant to one we are already aware of. It is not caused by blackberry hub but has to do with the number of saved contacts. We already have a fix but will be included in new beta release.
I would suggest you to register as a beta tester, in case you are not already and once the new beta is out (including the fix to the issue) update 3cx app, give it a try and share the results with us.
Reactions: nb and NickD_3CX
to add to what my colleague Apostolis said:
Thank you for your feedback especially the logon speed feedback.
If reception is not optimal there is nothing we can do.
Power drain - a new update is coming soon and this will completely solve the battery drains. The issue is caused because of Stuck Wake up locks - a phenomenon where on some devices the app is not killed when running in the background - this means that Android Sub might keep the app there running for hundreds of hours.. We have found out what happens and the next update will complete all the battery improvements we made.
The bug you reported will be fixed in the next update.
PS: how about bluetooth headset support for the Windows Softphone App - Selected headsets only - Sennheiser and others.
Yes subscribe to our beta program and join the hundreds of users who are already subscribed.
https://www.3cx.com/blog/releases/uc-android-client-beta/
Expect a beta update this week...
Mahlon
