Android on New Beta
curtcar21
Hi Im hoping someone out there can help me out. I just updated our in house system to the the newest beta version (15.5.15060) now our android app only works on WIFI. If not on WIFI it just says waiting for network. All thoughts are welcome
Have you double checked to make sure the tunnel is turned on for the extension you are using to test?
Yes I have. Thanks for suggestion though
Did you have that issue only at one Mobile App, or did you tried with a second Mobile Phone and 3CX Client App?
Multiple phones and many models including apple products.
When you are not on wifi and it fails, what ip address do you get from your provider? IPv4 or IPv6?
Can you contact me via pm? Like this we can try and debug from our test environment.
megalmazan
