Any tips to get round the untrusted call error in the event log?
Miragetek
Hi, simple setup, 8sc, 3cx hosted, v20, single supported sip provider.
Firewall test all green (as 3cx hosted should be).
However, looking at the event logs. Most of the calls are being marked as untrusted.
I've not seen these on other installs we have.
The kB mentions different parts of the call setup coming from different IP addresses. Which sounds weird.
Going to try and grab some wireshark dumps today to see what is going on. Thought I'd ask beforehand though in case anyone has seen this and has a quick config change to fix it. Think it may be causing calls to drop. However, still investigating at my end.
Was this resolved? Seeing similar and causing app calls to be rejected.
SDNM
