Anyone use a script to silently update 3CXPhone for Windows?
mcbsystems
With v16 SP6 comes a new version of 3CXPhone for Windows. I'd rather not ask all users to install the update; in fact, users without Windows administrative privileges can't do the update themselves, leaving me to log on to each machine.
I do have a Remote Management and Monitoring agent (RMM) on each machine that allows me to run scripts in the background. Just wondering if anyone is using a script or other means to silently update 3CXPhone? Are there any gotchas to this approach? In a brief test, the following command line stopped a running 3CXPhone and silently installed both 3CXPhone and a new VC++ redistributable:
msiexec /i 3CXPhoneforWindows.msi /quiet
We use to mass upgrade before server upgrades to avoid 3CX client "update pop-up":
%SystemRoot%\System32\taskkill.exe /f /im 3CXWin8Phone.exe
msiexec.exe /i "3CXPhoneforWindows.msi" ALLUSERS=1 /qn /norestart /log output.log
start "" "C:\ProgramData\3CXPhone for Windows\PhoneApp\3CXWin8Phone.exe" (as logged on user)
Thanks @3CXusername. Do you run that as a logon script? Wondering how you get the logged-on user context, especially since the installer requires elevated privileges.
BTW the taskkill seems to be handled by the installer itself now.
use PDQ deploy to set MSI step as system and start step to logged on.
Reactions: mcbsystems
Great, thanks for the suggestion.
[email protected].
