API Issue
Mg_PS
Good morning,
Following the loss of functionality in V20 which allows reports to be sent to users who do not have extended rights, I would like to recover them via the API.
https://www.3cx.com/docs/configuration-rest-api
Unfortunately, it is not documented enough. I can easily connect, list extensions, and others... But calling the GetExtensionStatisticsData function returns me a 404 error.
Here is the call in question:
HTTP:
GET https://xxxxxxx.xxx:5001/xapi/v1/ReportExtensionStatistics/Pbx.GetExtensionStatisticsData(periodFrom=2024-06-26T00:00:00Z,periodTo=2024-06-26T23:59:59Z,extensionFilter=,callArea= )
Thank you for the feedback,
The parameters values should be in single quotes even if empty.
Thanks for the fast answer. Unfortunatly same result...
What should I put to get all extension ?
What is "CallArea" ?
Putting "0" in call area does the job.
