API security code
REDFAC
Dear Team,
Kindly help us, we are try to configure API for 3cx, while obtain user token, we added username as Extension number and Password web client password, there's another filed "Security Code".,
please help to find out this.
Thanks,
Shabin
Dear Team,
Thanks,
Shabin
That's the 2FA code.
Thanks for the reply, how we can enable
You need to configure 2FA for the extension. You can use Google Authenticator for example.
Reactions: REDFAC
Thanks a lot, let me try.
Our Version is 18.0, is that supported
2FA , I can't see any settings to enable
If we cant use 2FA, Can we disable in API,
AshleyStokes
