API Webmeet Return 500
BrunoTeste
Platinum Partner
Good morning.
I'm trying to retrieve the meetings held so that I can download the recording that would be found in the JSON response, but the API only returns error 500.
Am I doing something wrong or has it been changed? The endpoint exists in nginx.
V:18.9A
Thank you very much!
Hello @BrunoTeste , it seems there's something unexpected in data and request cannot be fulfilled. Would you mind setting logs to verbose, send the request again, switch logs back to normal and share privately your logs? I will help you to troubleshoot.
arming
