Solved Apostrophe escape character in display names
telis
We've found that any display names with Apostrophes are showing: "O'" in place of the apostrophe on all voicemails.
I've found several posts dating back 7 years to say this will be fixed eventually but no confirmation.
Hi @telis,
What exact version of the PBX are you running? You can check this from the Dashboard, under Information.
Hi @telis,
I am seeing this both on 16.0.8.16 and 18.0 Update 2 (Build 314). The name of the person leaving a voicemail is reported with the "O'" in the subject line and body of the notification email.
Hi @telis,
Is the issue a visual one or is it causing an experience breaking problem at present?
Hi @telis,
For us it's more or less a minor cosmetic annoyance.
For the product I'd say it shouldn't be ignored. Getting someone's name right is important as a fact of basic politeness. Also for some people in some parts of the world, such as Ireland, the apostrophe in one's name can have cultural and political significance.
Hi @telis,
We don't intend on ignoring it, I was just wondering if it in some way broke the usage of the system. We will investigate further. Thanks for reporting this!
Hi @telis,
OK. Many thanks.
Reactions: VasilisV_3CX
Just a small update, we intend on making a change in V18 Update 3 to address this. For the time being, there is no ETA, but when it comes and you install it this should no longer be an issue.
Bluebox Global
