App rings while at desk
houston
One of the first questions I got setting up 3cx with a new customer today was how to prevent his cell phone and desk phone from ringing at the same time.
Best answer I could find was cumbersome, go into the app settings, toggle the account off. Which is bad, because while you might not want it to ring, you might want it to still show things like missed calls and voicemail counts.
It should be obvious that a user wouldn't want their cell and desk phones ringing at the same time. So it's a head scratcher to me why disabling the phone isn't handled better.
Some suggestions:
  1. Allow it to be set it by status - Available = At Desk, app doesn't ring, Away = away from desk, cell rings, desk doesn't.
  2. Autoset using GPS location
  3. Autoset using WiFi network name
  4. Autoset using Visible BlueTooth devices
Using call forwarding to cell instead is not an practical answer. Outgoing calls often cost money. Data usually doesn't.
Setting the app up as an additional extension is also impractical because it makes voice mail, call history, contacts, etc. complicated.
I'm using two ways :
  • As you do, disable the account
  • Log into an other extension on the same system, then you can check voicemail, see missed calls if it's a queue (and u unlog of the queue) or RG and stay Away or smthg
This will be available in SP3 Beta from what we know. They though of it since "Exit (Ignore Push)" is no longer there.
Reactions: CKFIT
I think end users would prefer "magic", like detecting nearby bluetooth. But I like hearing that the status changes might control it in the future. I prefer "manual" because "magic" is often flaky ;) Manual means they're less likely to call me asking why "it's broken".
in 3CX version 16.0.2.910
The Android version has Exit - Ignores PUSH in the menu
The iOS version does NOT have Exit - Ignores PUSH in the menu
Mahlon
