Solved App team sort settings
AWS2P
could it be possible in future release to have new settings to choose if we want to sort team by alphabetical order or by extension number and from A to Z or Z to A , and same logic for extensions numbers.
And last thing, your own extension not to be defaulted in first line as you rarely need to search yourself and so it could be in the alpha order or extension order like others.
Thanks if this could be done in future updates :)
Hi @aws2p,
Please note that feature requests should only be requested from the ideas section of the forum.
Please check there if it is already been requested and upvote it, for a greater chance of it being noticed.
Please also note that Gold, Platinum and Titanium partners are able to post idea requests. If the idea is not already there, then you may need to get a higher level partner of 3CX onboard to post this for you.
We recommend using that section of the forum as many ideas in the other sections will be lost with the sheer number of threads we get in the forum!
Hi Nicholas
Thanks for the answer;)
as no more bird of the year xD i know this
@aws2p Hi there, and hope you are well.
We will close this thread here.
SDNM
