Appliance working but can't get ports to pass
TECH198
New User
When running ports on appliance, all ports pass expect ALG, ports 5060 and 5061... the box is going through Sophos and ALG is disabled on it..
Must I also open ports on router as well?? as technically firewall connection test originated from inside LAN going OUT, not coming in
The way the firewall checker works will also cause traffic to come in on a different port and from a different IP so yes, you do need to configure your network firewall too to allow incoming traffic on all required ports: https://www.3cx.com/docs/ports/
You might want to check out our guide explaining how the firewall checker works if you need more information: https://www.3cx.com/docs/firewall-checker/
We also have a general firewall configuration guide which also contains links to guides for commonly used firewalls which you might find useful: https://www.3cx.com/docs/manual/firewall-router-configuration/
Note: Do bear in mind that the firewall versions the guides refer to are whatever versions were available at the time the documentation was created.
gmacinit
