Auto-update, Improved Components and Better Error-handling with latest CFD release
  • Thread starter Thread starter Constantinos Constantinou
  • Start date Start date
The Call Flow Designer’s stream of updates continues bringing users an auto-updater, new C# components, UI updates and improved error control. All in all, this is a must-have CFD release to get and start building your voice apps for v16 Update 1.
Development Environment Updates​
The latest IDE (Integrated Development Environme...
Reactions: edossantos and jed
we're lagging a little as the flows created in CFD for v15.5 are integral to our main project.
is there any kind of guide for the upgrade process from 15.5 to 16 (update1?) with a particular consideration for existing CFD projects?
other than the base upgrade process of
IF 3CX on WINDOWS Do the following:
1.Take a backup of your existing install
2.Uninstall 15.5 install
3.Download and install this https://downloads-global.3cx.com/downloads/3CXPhoneSystem16.exe
4.Restore backup.
5.You will be on the release candidate. You will have everything you need in place.
6.You will be able to continue from this point onwards updating 3CX via updates
we will be trialling the migration using an NFR keyed installation (Enterprise I think) and then hopefully deploying what we learn from that to a 15.5pro to 16pro Migration (we'll take the opportunity to move the installation from Win2012 to Win2016 VM) and a second new installation on another clean Win 2016 VM.
The way I see this going is the current 15.5pro backup will be restored to a new 16pro installation with the keys included and then a second 16pro installation (internal HA failover server) with a new key & FQDN
AshleyStokes
