Auto Update Won't Update Phone Template
myrich22
Forum User
I have the auto update set to daily. For some reason, there is a phone template update that won't auto apply. I've tried to manually apply and it won't let me select. Update has been out there for about a week. I have many phones that would get this update. The home page and extensions gives an error message that my phones are not supported. But, the compatibility page says they are ok (Yealink T46S). I tried rebooting the 3cx server without any luck. Ideas?
Did you firstly select the row "Yealink T23,T27,..." and then click "Download Selected" button?
Ahh... that was it... Going to hide under rock in shame... I guess I was looking for a checkbox rather than a row select. Anyway, all ok. Thanks!
Auto update is mostly just for the pbx itself, not the Templates, SIP trunks, Gateways.
3K8iMGWviZ
