Solved Auto Upgrade failing
deanrose
Hi All -
I've got an Amazon Lightsail 3cx instance whereby the auto-upgrade is failing every night. The error log file is provided below and I'm assuming I should attempt to run the "apt --fix-broken install" as its suggesting but not sure how to do this on Amazon Lightsail. I'm on 16.0.0.1581 trying to go to 16.0.1.273. Any suggestions on how to remediate would be greatly appreciated.
reading package lists...
Building dependency tree...
Reading state information...
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
apt-utils : Depends: apt (= 1.4.8) but 1.4.9 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Rollback to 16.0.0.1581...
Reading package lists...
3cxpbx is already the newest version (16.0.0.1581).
New 16.0 Update 1 ReleaseOut Of Date16.0.0.158116.0.1.273
Nevermind - Fixed it with the following command in Lightsail:
sudo apt --fix-broken install
Reactions: YiannisH_3CX
You gave us yourself, in your first post, the answer on what has to be bone. just need to read.
Now you've applied fix to your PBX, you are up to date . good job, well done :)
devo.it
