Automatic Status change
:) It's available to you, the user, but not to the application.
Then there is still GPS-location where the app could check to be silent or not ;)
On iOS, developers should prove Apple Review Team their app provides user location-specific functionality, like Maps - hidden functionality like the one you suggest would not be approved (I know this for sure because our iOS client has been rejected about eight years ago exactly for this reason)
I just installed a wifi-analyzer on a iPhone, and they do see the SSID name "KVIKDMZ" we gave our router! So I'm shure the 3CX-app would be able to see our company name "KVIK" and thereby allow to ring the 3CX app ;)
So please add a future that doesn't let the 3CX make any noise or notification when the wifi-connection doesn't have a specific text in the SSID-name.
Maybe you as a "Staff member" should add this to the feature request ;) I't took me a while to convince you, so maybe you find the correct words to explain this better.
In the time being, I'll going to remove that app and only use the computer at the location where I only want to be reachable. :( or find some other software...
Maybe you as a user should listen to what a staff member tells you. There is a reason why I tell you to add it. Features are decided via a voting system. Similar to how you elect members of parliament. If I open it, they just see me opening it. If you open it, they add +1 to the count of how many users opened it. Then the more points a feature gets, the more the chances of the feature being implemented. Now if you are not enthusiastic enough to open it and follow instructions, then I guess you should not be complaining.
Just look at the wifi name ;)
For us we could have multiple wifi's all with the name kvik3CX in it: kvik3CX1, kvik3CX2, kvik3CX3,....
No you cannot use wifi name - that is called elementary classroom programming. You need to use something unique. If any we will keep a mapping between ssid and public ip. Don't worry about explaining and about the internals. Your job is to open a one liner - something like this - Ability to remember wifi networks, add them as favourites and set a working status profile to be automatically set when that wifi is active.
Start from opening the description first and we will handle the technicalities when and if the time comes.
Infinity Network
