Avaya to 3CX SIP Trunk call failed
kirankumar2202
We are trying to establish the SIP trunk between Avaya PBX with 3CX with out other office we are getting the inbound call. However, after first 2 rings the call gets terminated. and below are the logs.
01/06/2023 3:46:40 PM - Default best-route IP is determined as 172.30.34.54
01/06/2023 3:46:34 PM - Leg L:22.2[Extn:683] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01/06/2023 3:46:34 PM - L:22.2[Extn:683] got Terminated Recv 487/INVITE from 127.0.0.1:5063 tid=be63d8344b35e709 Call-ID=21aghSWDb55e5kRe9G4eQA..:
SIP/2.0 487 Request Terminated
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-524287-1---be63d8344b35e709;rport=5060
To: <sip:[email protected]>;tag=275e2153
From: "301"<sip:[email protected]:5060;nf=e>;tag=17121a58
Call-ID: 21aghSWDb55e5kRe9G4eQA..
CSeq: 1 INVITE
User-Agent: 3CX WebRTC proxy
Content-Length: 0
01/06/2023 3:46:34 PM - Terminated from <sip:[email protected]>;tag=275e2153 to "301"<sip:[email protected]:5060;nf=e>;tag=17121a58; reason: Error
01/06/2023 3:46:34 PM - L:22.2[Extn:683] got Failure: Failure Recv 487/INVITE from 127.0.0.1:5063 tid=be63d8344b35e709 Call-ID=21aghSWDb55e5kRe9G4eQA..:
CSeq: 1 INVITE
Content-Length: 0
01/06/2023 3:46:34 PM - [CM503003]: Call(C:22): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01/06/2023 3:46:34 PM - Session 536601 has failed in leg L:22.2[Extn:683] ; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5063
01/06/2023 3:46:34 PM - Failure from <sip:[email protected]>;tag=275e2153 to "301"<sip:[email protected]:5060;nf=e>;tag=17121a58
01/06/2023 3:46:34 PM - ~Target=Ext:Ext.683
01/06/2023 3:46:34 PM - Leg L:22.1[Line:10001<<301] is terminated: Cause: BYE from PBX
01/06/2023 3:46:34 PM - Terminated from "" <sip:[email protected]>;tag=e73289673328704f to <sip:[email protected]>;tag=f4480441; reason: Rejected
01/06/2023 3:46:34 PM - L:22.1[Line:10001<<301] Sending: OnSendResp Send 604/INVITE from 0.0.0.0:0 tid=e069ed3f8abc9f5a9cec913b3474004c Call-ID=908c63b3d3c3c1b9e2f4e7d9ebbd0291:
SIP/2.0 604 Does Not Exist Anywhere
Via: SIP/2.0/UDP 172.25.1.2:5060;rport=5060;branch=z9hG4bKe069ed3f8abc9f5a9cec913b3474004c
To: <sip:[email protected]>;tag=f4480441
From: "" <sip:[email protected]>;tag=e73289673328704f
Call-ID: 908c63b3d3c3c1b9e2f4e7d9ebbd0291
CSeq: 1996036303 INVITE
Warning: 499 SPJSYD-33.spjainsyd.local "No outbound rule"
Content-Length: 0
according to the log there is "No outbound rule"
What type of trunk are you using in 3CX...a Bridge trunk, Generic trunk?
youwillbrun
