Backup bug after SP5
VictorC
SOHO User
It looks like the lastest update broke the backup system. Can any one confirm?
If I log into a box and go to BAckup and Restore I get
"Not logged in, this user account is currently unavailable."
Hi VictorC,
Just tested this on my SP5 system and this seems to work perfectly fine for me. Perhaps try logging out of the PBX and back in again, or changing user account.
Hi VictorC,
I've also just tested on an updated SP5 install and that section is available as normal.
You may need to contact 3CX support.
clear web cache.
Hello @VictorC
Make sure that you are using the admin account of the PBX and not a user account to eliminate that possibility as well.
gmacinit
