Battery device drain, when application not exited
davdialn
New User
There are 2 types of exiting application: EXIT and EXIT ignoring PUSH.
If you don’t EXIT the application when not used, but simply put into background, it will drain significantly the battery of the phone, like it is active all the time. Normal EXIT should allow client to be awaken on receiving PUSH notifications.
This problem should be fixed somehow, as exiting manually the client, after each usage of the application / bringing into focus is rather boring.
I've tested this behavior with several different Android phones -- Samsung, Sony and LG.
These options are actually no longer available, meaning you are probably running an older version.
Which version of 3CX PBX and which version of the 3CX Android are you running?
Stephan Eusebe
