Bench build up
VictorC
SOHO User
Hi all, we are starting to do a good amount of systems and it would save a lot of time to build some of these on the bench, the problem with this is would not know the IP's of most and do not want to go thru the trouble of finding them out and ticking 3CX during the install to see it.
My question is it worth use DHCP in this case and will it hurt anything?
Hello @VictorC
Please note that the current version of 3CX has the ability to change the local IP without re-installing the system so you can actually build a system and then have its local IP changed. The public IP could always be changed after installation so that is not an issue.
Of course setting the correct local IP from the start saves you an extra step you need to perform on the clients site.
Set the public IP to dynamic so the change is detected once the machine reaches the client.
cmedina
