Solved Beronet GSM
siscom
Good Afternoon Colleagues
May i know if beroNet VoLTE is the same as berofix 400 or its new version ?
Best Regards
Hi @siscom,
Most beroNet devices are modular, so the SIP configuration you would need to do to make it work with 3CX shouldn't differ much from what is described here: https://www.3cx.com/voip-gateways/beronet-berofix-400/
3CX hasn't specifically tested the VoLTE model, but I suggest you contact beroNet and ask them, they are very familiar with 3CX and they should be able to advise you.
Thanks so much for your feedback
Kayla Norris
