Beta 16.7.7.118 Can't answer calls from bluetooth Galaxy S9
UlrichBerger
SOHO User
since last update I can't answer calls through bluetooth(car, headset) anymore. Before it worked without problems.
Beta Android 16.7.7.118 Samsund Galaxy S9 Android 10
TelecomAPI enabled
audio subsystem Open SL
Already uninstalled und installed again.
Can you please check if the same thing happens without a bluetooth device connected too?
Do also check if disabling/enabling Telecom API in Menu >> Settings >> Advanced changes the behavior (without any bluetooth devices connected).
It makes no change if the bluetooth option is enabled or not.
I can always answer the call from the phone screen, but not from the bluetooth device. I'm getting the caller ID on the car normally, but the pic-up button of the car doesn't pick up the phone. I must answer from the screen.
Also from the bluetooth headset I can'T answer by the button, only from the phone.
Before the last update it worked.
I'll PM you shortly regarding this issue.
@UlrichBerger
As per our conversation via PM, the newly released Android BETA version 16.7.8.121 seems to have resolved the issue!
If anyone reading this has any similar issues, please give it a try and let us know!
Stephan Eusebe
