beta version 16.5.1.53 & contact
ags
I find that I don't see all the contacts in Company and Personal.
with the official version ( 16.4.4 ) I see all contacts correctly
Giulio
Hi @ ags, please provide more info on your Android device (model, OS version), the PBX (version & OS), as well as the type of PBX contact integration you are using, if any.
PBX v 16.0.655 OS debian;
Android device huawei p30 lite OS 10
the problem are the contact insert or modify trought webclient
are not dispaly in the device
if i insert from device is ok but if next i modify from webclient, the contact is not display on device
Reactions: Vali_3CX
@ags thank you for the provided info. We have confirmed the described case and are working towards a fix to be included in an upcoming beta release.
In the meantime you can perform a search for the contact, which immediately refreshes the addressbook.
Looks like I also miss some contacts. If I perform a search the contact is not found. however, my contacts originate from exchange.
Is there a way to get the number of contacts in the 3cx address book?
Yes, you can easily export your contacts from the Management Console in 'Advanced' > 'Contacts' > 'Export' and use a text editor or spreadsheet app to count the exported lines.
But this function only seems to expor the "company" phonebook, not the 3cx personal? I would like to compare the personal pbk synced from Exchange with Exchange.
Such a feature / function is not currently implemented. You can perform some sample search queries though for specific contacts to confirm that they have been synced.
for information, we have the same problem with the official version for android phone : 16.5.2
Cordially,
ciao,
with version 16.5.2.55 the problem was not solved
Giulio
DejanMDS
