Solved Black screen on incoming calls if screen locked.
PleaseSpecifyAUsername
Forum User
I've one user with the following problem:
In case of incoming call, if the phone is locked, the phone rings but no notification is shown on the screen. If the user slides down the screen, she can click on "answer" but then it doesn't answer, it just stops the ringing but that doesn't end the call. When the caller finishes the call, a notification is shown on the phone for a missed call.
If the phone is not locked, the app works perfectly.
We've tried the following :
- Turn on all possible notifications (as explained on other threads) -> No change, everything was already active.
- Check/uncheck the "Car/Bluetooth support(Telecom API)" function. If we check this box, the phone doesn't ring anymore on incoming calls.
- "Turn off battery usage optimization" -> No change.
The phone is running on Android 9 and the 3CX App is v16.7.8.121.
Thanks in advance for your support.
Could you please also provide the exact brand, model name and model number as seen in "Settings >> About Device"?
The model is Cubot x19, CUBOT_X19_9021C_1_V08_20190627
This sounds similar like problem I had with the sony - where you made a fix meamwhile.
We plan to release a public beta today which includes this fix.
Is it possible to try this public beta? Where can I get it?
Regards,
Regards,
You should be able to install the Beta right from within the Google Play Store. Just search for "3CX" as you would normally, open to see the details, and if you scroll down a bit, you will see the option there to join the Beta.
The beta version has fixed the problem!
Thanks a lot for your help.
Regards
Glad to hear this is sorted!
Please feel free to start a new thread should you need anything else!
