Solved Block extension to extension calls
xavier5788
What is the best way to block an extension to call another extension ?
I want some extensions to only get called and not to call.
I can disable external call from an extension in the extensions options but I couldn't find something to block calls between extensions.
Thank you in advance
3CX Management Console - Extensions , edit your extension, Forwarding Rules. At the bottom of the screen you will see 'Exceptions'
Enter the extensions you want to block in 'Calls from Caller ID'. I believe you can enter a block of extensions by entering 100 - 120 or you can enter 100, 102, 110 which will block ext 100 & 102 & 110
Forward to select 'end call'
Hello Saqqara,
Thank you for your prompt answer. This is exactly what I was looking for. Works. Thanks and have a great day!
Glad to see the issue has been resolved and thank you for updating the thread.
Bluebox Global
