Bulk configuration 3CX Client Windows
epress
I'd like to know if there is a way to do a "bulk" configuration of 3cx windows clients, because i have to configure the option to replace the + with 00 in every client and i I wouldn't like to configure one client at a time.
Thank you
Hello @epress
I am afraid that that option is only configurable through the 3CX client so it has to be done manually on each client.
Hello @epress
Thanks Yiannish for your answer, do you know if it will be available in the future the bulk configuration for the 3cx client?
Because i think it's a very useful option for middle/large installation.
Best regards
I am not aware of any plans regarding this currently. I would recommend posting your idea on https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
Hi @epress
We have removed the shortcut from the startup folder and instead launch a VBS script to modify the 3cx phone configuration file and then launch the softphone.
Not supported by 3cx, obviously... and may need reworking for any future softphone updates - but for what it's worth...
Set xmlDoc = CreateObject("Microsoft.XMLDOM")
Set objShell = CreateObject("WScript.Shell")
userProfilePath = objShell.ExpandEnvironmentStrings("%UserProfile%")
xmlDoc.Async = "False"
xmlDoc.Load( userProfilePath & "\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml")
Set colNodes=xmlDoc.selectNodes("/Accounts/Profiles/Profile/AutomaticallyOpenChatWindow")
For Each objNode in colNodes
objNode.Text = "True"
Next
Set colNodes=xmlDoc.selectNodes("/Accounts/Profiles/Profile/InternationalDialingCode")
objNode.Text = "00"
Next
Set colNodes=xmlDoc.selectNodes("/Accounts/Profiles/Profile/UseInternationalDialingCode")
Next
xmlDoc.Save userProfilePath & "\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml"
objShell.Exec "C:\ProgramData\3CXPhone for Windows\PhoneApp\3CXWin8Phone.exe"
Set objShell = Nothing
This enables chat auto-popup and sets the conversion of + to 00
Reactions: jed
Hi @epress
Next
objNode.Text = "00"
Next
Next
Thank you @jonpennell
I'll try this solution.
gmacinit
