bulk extension and elastix batch extension problem
witekprytek
Hi;
I used to use "bulk extension" module from freepbx to create some extension sets.
This module has always worked fine for me, but in elastix 2.2 extensions created in this module are not visible on the elastix extension configuration page. There are also not presented in files exported using the elastix "batch extension" module.
I do not use elastix batch module, because it has very limited options which could be configured for the extension (e.g follow me)
Is there any way to make extension created and configured from freepbx to be visible elastix configuration?
All extensions work and all devices are able to work, but whole configuration have to be made under the freepbx page.
Apollo Cloud
