Bulk update Outbound Caller ID
pmterp
Gold Partner
I have a few hundred extensions within 7 different groups and I need to update their outbound caller ID numbers.
I tried exporting, editing the field, and then importing but it fails since the extension numbers already exist.
I'm aware of the option to hold CTRL and click multiple extensions but Outbound Caller ID isn't an editable option that way.
Any other suggestions?
It is a property of the extension (DN?) which could be updated with a custom application using the Call Control API, but it might be faster to just edit each extension rather than create a application just for this purpose.
Hello @pmterp
I believe the best option is to manually update the outbound caller ID of the extensions. You could also create a feature request regarding this on our ideas section of the forum:
https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
megalmazan
