C# - Audio bus instead of PromptQueue usage
Adion Cloud
Trainee Partner
We are developing a custom application in C# that requires the use of the real-time caller channel and real-time audio playback without going through a temporary .wav file or a PromptQueue.
Can we retrieve this audio stream with an argument? What does the MyCall variable do?
Alternatively, we will have to develop a SIP client that will do the necessary in place of the call flow designer. But we prefer to integrate this more easily through the cfd.
Have a nice day.
The Call Flow Designer does not provide direct access to the audio stream.
Reactions: edossantos
You will have to create your own SIP client to achieve that.
Reactions: VoIPTools
Thank you for your'e answer. I think i need to do this on C# .net core for linux usage.
Do you know good SIP SDK ?
3CX uses resiprocate, but I'm not sure if there is a C# port for it.... You should google around a bit and see what you can find.
Resiprocate's based on c++. I think is it powerfull ! I will try to build it and work with mono framework for linux purpose.
I found Ozeki SDK. But very old for a new project.
cur_cb
