Call Flows - Cloud Hosted
Kevin.C
Hi.
I am wondering if call flows can be used on the Cloud Hosted 3CX servers.
I do not see a section under Call Queues called "Voice Apps".
If this is not supported now, will it (or another similar feature) be supported in the future?
Regards
It does on Pro and Enterprise.
Like @neville mentioned this is a pro or enterprise feature. Since all 3CX hosted installations use a standard licence the option is not included.
gmacinit
