Solved Call limit per queue
delis
Platinum Partner
Hello all,
Is there any way to limit calls per queue?
We have 3 queues in an instance, one DID number.
We would like to limit 10 inbound calls per queue, on a 32 CC instance.
Thank you.
Yes there is!
All you need to do is set the "Maximum Callers in Queue" parameter under " Call Queues >> Edit >> Advanced >> Queue Preferences":
Note: Its default value is 0 meaning it's unlimited.
Thank you, it seems that i am blind :)
I have checked Advanced settings one thousand times.
Reactions: ChrisC_3CX
No worries! We've all been there!;)
devo.it
