Call Reports
Tarheels
Platinum Partner
I have a customer that is running call reports at the beginning of the month and the reports only show thru the 11th or 12th. I did a call report myself and it did the same thing. Has anyone else run into this problem.
Which version you are running, did you tried to play with range instead of last month you can set it as last 30 days and give it a shot . Then try to use the custom range as well.
Version 15.5.6354.2 and I tried the custom range and it still only gave me the first 10 or 11 days
This most probberly will be because you have to many entries in the Report,
I just ran a report for last 7 days, but have only 2 days of records in the Report, that contains 7179 calls, and shows 397 pages..
Subject: 3CX Phone System - Test
Your call report - Test is ready for download.
Download your report from here
* Report not generated in full because query contains too many records.
You might have to create 2 or 3 reports to cover the month..
Reactions: YiannisH_3CX
Herm77
