Call transfer Back on no answer
Tin Nwe Win
Gold Partner
Dear 3CX Expert Team,
Can 3cx work with blind transfer call back on " No Answer "?
Thanks for your support.
Regarding your question, it can only work when the extension the call is transferred to is busy.
When not answered, it will follow the forwarding rules of the extension the call is transferred to.
Reactions: Tin Nwe Win
Noted with many thanks.
Thank you very much for your prompt support.
You are welcome.
  • Love
Hola,
Es curioso que la call back funcione en GrandStream, pero con teléfonos SNOM, no.
Imagino que será por la plantilla que tiene cada teléfono de fábrica. Mi problema se produce con SNOM y a pesar de tener las configuraciones de las distintas opiniones del foro, no consigo hacerlo funcionar.
AshleyStokes
