CallReport problem
Martina
Hallo,
I create a simple xml template for testing with CRM template generator.
But the scenario ReportCall give a error:
System.Exception: Unknown expression: Agent. Part: Agent.
in TcxLexicalParser.ValueManager.GetByPath(String[] path)
in TcxLexicalParser.LexEvaluator.Process(Element element, IValueManager valueManager, Boolean isFunctionArgument)
in TcxLexicalParser.LexEvaluator.ProcessInt(ConcatElement concatElement, IValueManager valueManager, Boolean isFunctionArgument)
this is my xml:
<?xml version="1.0"?>
<Crm xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Country="US" Name="test" Version="8">>
<Number Prefix="AsIs" MaxLength="[MaxLength]"/>
<Connection MaxConcurrentRequests="10"/>
<Parameters>
<Parameter Name="URL" Type="String" Parent="General Configuration" Editor="String" Title="URL:" Default="http://192.168.1.56:8080/" />
<Parameter Name="ReportCallEnabled" Type="Boolean" Editor="String" Title="Enable Call Journaling" Default="True"/>
</Parameters>
<Authentication Type="No"/>
<Scenarios>
<Scenario Id="" Type="REST">
<Request Url="/webservice/chiamate?operation=getc...l in console give me a same error. Thank you
Sorry I solved the scenario without is was completely wrong
Senergia
