Can I rename sbc tunnel?
ZenMasta
I noticed a while ago that our sbc tunnel has an odd somewhat random name. I have never set this name personally, and we've been running since v11 I think.upgrading along the way, so I suppose at some point 3cx renamed it automatically.
sbc.randomlettersandnumbers.3CXSBC15.5.morenumbers
I'm assuming that I can change this but I'd just like to make sure. Would I also need to do anything on the on PC where the sbc is hosted?
If it's just the display name, it's under SIP Trunks > click the SBC > Connection Information > Name. You can rename that.
More often than not, once created, you cannot re-name entities, on 3CX. I suspect, that if the name change is important, then you will have to create a new trunk, using the same information, during an "off" period.
Not the case with SBCs though :)
I stand corrected. Had not attempted an SBC re-name before. I had incorrectly assumed that they had already, unsuccessfully, attempted to re-name it.
Senergia
