Can not save settings in the webui for some extensions
Justin Eastridge
This problem began a week ago. I noticed that some extensions could not be changed. I can not edit it at all. When I hit the blue 'OK' at the top it does nothing. I have found no errors in the logs. In Firefox I decided to inspect the element and it shows an error (I removed our subdomain for security reasons.)
Code:
XML Parsing Error: no root element found
Line Number 1, Column 1:
On Chrome I see something similar
We are running 15.5SP5 on Linux.
Hello @Justin Eastridge
If you are pressing the OK button and nothing happens that would suggest that a setting in the extension is not correct. Navigate through the tabs and check that all settings are correctly applied.
For example check the codecs under options and that a mobile number is present if you have a forwarding rule that forwards to mobile.
That was my thought, but I see nothing lighting up in red. It does seem like a field is empty but I have no idea what one. I can continue to troubleshoot but I don't know what field could be off. I went through all the tabs for the extension.
Check the extensions passwords for special characters and try again.
Bastion Advisory
