Cannot pick up incoming calls
phuonglinh96
I have installed and configured the 3CX soft phone and all appears to be working, I can make outbound calls successfully.
I cannot however pick up incoming calls, the soft phone rings and I click the green answer button but the call keeps ringing, I've tried pressing enter on the keyboard but I just can't answer.
Any ideas?
Linh
Hi Linh,
Local calls should be the easiest to get working so it must be something local, either to the PBX or the network.
Consider checking the following:
* Do calls work if Windows firewall is turned off (check the machine you are testing and 3CX - if the PBX is running on Windows).
* Again on both machines is .NET Framework and Windows updates currently up-to date.
* Is your network using VLAN's, is so in most cases your soft-clients would reside on the DATA network and hard-phones (if using) and potentially the PBX would be on the VOICE so you would need some routing between both for these to work.
aatroxadrian
