Can't access Elastix :(
nisar72
Hi Everyone.I have Installed Elastix on VMware Workstation and given DHCP IP address after Installation when I access Elastix with mozilla I get response like this "The connection has timed out
The server at 192.168.79.128 is taking too long to respond." :(
Means I could't access Elastix.Please help me out from this problem.I will be Very thankful to you all.Thanks :)
The first thing that you need to do is to check the real IP of your elastix server, execute:
ifconfig
then try to ping your server from your PC, if you get any response, then check httpd status and try to login again.
Thanks It works
Thanks for reply.Thanks It works .Thanks for support
CLTedu
