Can't Connect to Webclient
DaveSa
Everything was working peachy with our 3cx system. Then, last week, we had to replace our router, and now we are having problems.
Everything works with our phone system, EXCEPT, we are unable to connect to:
[COMPANYNAME].east.3cx.us:5001/webclient/#/people
When we try, we get this message: Disconnected. Waiting for network.
We ARE able to connect to the 3CX management console.
If we try from a computer outside our network, we have no issues. It is just our internal network. I've checked all ports and they seem to be fine. I just can't seem to figure out this problem.
Do you get the same issue if you try when using the PBX's local IP?
Such as: https://<PBX_LOCAL_IP>:5001/webclient
On the internal network does an nslookup of the fqdn resolve to an ip address.
If it does not resolve, I would guess you are missing a dns setting that points the 3cx fqdn to the internal ip address.
I can access correctly using the local IP address
In that case, this might be related to the fact that when using the FQDN, you are resolving it to the public IP and therefore have the PC attempt to connect to the network's own public IP which may sometimes not be allowed or cause issues depending on your network/firewall configuration.
If you have a local DNS server for this network, you could add a DNS entry to have the PBX's FQDN resolve to the local IP, as Saqqara mentioned, instead.
When I run a NSLOOKUP from windows I get:
Server: [xxx].east.3cx.us
Address: Our EXTERNAL IP address
*** [xxx].east.3cx.us can't find nslookup: Non-existent domain
That is your issue, it should resolve to the internal IP address or configure the firewall to point the fqdn internally instead of trying to go out and back in via the firewall
What firewall are you using.
Reactions: ChrisC_3CX
Honestly, we just use the router provided by our internet provider, which is Frontier . The router is model NVG468MQ
Try this, access the web front end of the router
Under DNS - add a manual dns entry
Hostname - 3cx fqdn
IP address - internal ip address of server
Thanks all. I'll give them all a shot.
estrezacafe111
