Solved Can't remote a yealink T57w
luc.jubeau
Platinum Partner
We have a user who have her webclient and a yealink T57W.
She would like to launch a call from her webclient through her yealink T57W.
She has a message "make a call".
how to do to not have this message ?
We are with 3cx v18
thanks for your answer
Please check the following:
1. The phone is running the correct FW version - the current 3CX-supported version for the T57W model is 96.86.0.74
2. The Webclient dialer is using the Yealink T57W as a "Call using:" device
the version of Yealink T57W is 96.76.100.5 (we've updated it by web manager)
She uses "call using Yealink........" but that does : "make a call " on the phone
that's the issue.
Downgrade to the correct supported firmware.
This is a known issue with that firmware.
OK
i will downgrade tomorow morning.
thanks for your answer.
Thank you !
the issue was solved.
Finatra.us
