Solved Can't renew maintenance
lenhodder
Forum User
I'm having a problem getting my maintenance renewal to process. It's giving me an error "Invalid Parameter 'StateCode'".
Suggestions? Anyone I can contact inside 3CX about this?
Thanks!
13339
Thanks for pointing this out!
I have notified the licensing team and they are currently looking into this.
Hi lenhodder
You need to fill in the Address Information and select an address from the drop down.
13344
If there is anything missing from the address that is can be found by google maps then you can also fill in the additional address information.
Thanks. That worked! Not obvious, though.
Reactions: NickD_3CX
Kayla Norris
