Solved Can't renew maintenance
denpere
I'm having a problem getting my maintenance renewal to process. It's giving me an error "Invalid Parameter 'StateCode'", even using the drop-down to fill in the address
. 13975
Suggestions? Anyone I can contact inside 3CX about this?
Thanks!
Hi @denpere ,
It is mandatory to use the drop-down to fill in the address as well as specify a state. Can you send me a private message with a screenshot of what you see after you make a selection from the drop-down list? (make sure the error is shown)
Solved.
Greetings and thank you
Hi @denpere ,
You're welcome! Marking this as solved.
natedog
