CDR Help
BCS-Tech2
I have search everywhere and cannot find information about what the different CDR codes mean. I.E. QFwdToDNA.
Does anyone have a list of the CDR definitions?
Reactions: VoIPTools
Yes, I had already read that document, but it says nothing about the codes themselves. The information you sent is good about QFwdToDNA but what about the rest of the codes.
I know QFwdToDNA might not be so clear but if my memory serves most of them are quite self-explanatory. I guess you could always check the corresponding call report entry if you see a CDR that you do not understand.
Is there a specific one that you info for?
No, just a list of the codes and definitions would be good to have. Odd that the list does not seem to exist.
Thanks anyway.
gmacinit
