Certificate Error
Heath
When I enter the website for Management Console Portal, I'm not getting an error that says there is a problem with the website security certificate.. And says that the website is not secure. And is says The hostname in the website’s security certificate differs from the website you are trying to visit. Error Code: DLG_FLAGS_SEC_CERT_CN_INVALID... When I go to view the certificate it does have the FQDN of my PBX, and valid 7/24/21 to 10/22/21.. I use the certificate of 3CX.. I have never received this error before, and all of a sudden now I am..
Now I have accessed the management portal after 7/24 and no error... I cleared out my cookies, history, etc.. Rebooted, and still have this error.. And getting on multi computers, not just one at different places, different public IP.. How do I fix this
The fact that you got that message without it actually applying is strange.
Do you happen to be managing a number of 3CX PBX sharing similar FQDNs? If yes, what I recommend you try first is run a DNS query for everyone using:
Code:
nslookup FQDN
and check if you happen to have two of the pointing to the same Public IP.
I have a few FQDN. But they are different. I tried the nslookup and only 1 pointing to the public IP
Are you still facing the same issue from different locations and different PCs as we speak?
I'll PM you shortly for more information regarding this issue.
estrezacafe111
