jasonhille Silver Partner Advanced Certified Joined Sep 13, 2019 Messages 24 Reaction score 7 Aug 30, 2024 #1 I upgraded to Version 20.0 Update 3 (Build 659 Alpha) today, from Update 2. The location for the FQDN public certificate used to be located here: C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1 Has this moved to here?: C:\ProgramData\3CX\Bin\nginx\conf\Instance1 Reactions: jed
NicholasP_3CX Support Team 3CX Support Premier Customer Advanced Certified Joined Apr 25, 2014 Messages 2,487 Reaction score 2,357 Sep 2, 2024 #2 Yes, that is correct. Reactions: jed
VoIPTools 3CX MVP Platinum Partner Joined Feb 13, 2013 Messages 3,884 Reaction score 1,931 Sep 3, 2024 #3 What if 3CX is installed on the D: drive? Will the location change, or will it continue to be written to the C: drive?
