- Joined
- Jul 7, 2022
- Messages
- 23
- Reaction score
- 0
HI All
Would you be able to tell me how to add a logger to the current credit card capture flow (or where I would have to situate this) to log any error data please?
Currently I have this set up, we are going through the process via the allocated extension - all API and web service are correct however we keep encountering invalidation errors
I would like to understand if the data is actually transmitting to our payment gateway or if its something at the front end that need addressing as currentely they cannot see any attempt for connection at their end?
Does the Logger option do this? And if so where does it store the information? Ive currently added it AFTER the Validate Credit Card part of the process - is this correct and what would I need to configure
it as to capture any relevant data?
Your help would be greatly appreciated
Jase
Jase
