Solved CFD - MyCall.Info - where does it go ?
A.Takacs
Hello
Guess more or less self explanatory. Where does the CFD MyCall.Info (...) directive log ? Does it need a specific logging level ? Is there a reference guide for CFD ?
Sorry possibly a bit lot here...
It logs to the 3CXCallFlow.log file. You need to ensure that the server activity log has the logging level set to Medium at least to get it to the file.
Thanks. Is that log available from 3cx hosted instances in v20 (sorry might not be looking at the right place)
Yes, you can download if from the 3CX Console > Admin > Dashboard > Troubleshooting > Support Info. This will download a ZIP file, and you will find the log inside that file.
